Login Error
Close
How to Check Your Cell Phone Voicemail from a Landline
by DoItYourself Staff
Cell phone voice mail is very useful in case anyone calls you when you're not available. However, when you check the voicemail from your phone it will often cost you money.
Instead, you need to find a way to check your voicemail without using your cell phone. One of the best ways of doing this is checking your cell phone voicemail messages from your landline phone.
Register
Talk to your cell phone company and ask them to register you for a PIN (Personal Identification Number). You need to set up a secure PIN so that you can access your voice mail from another phone. They should also give you the access number to phone into the voicemail system.
Phoning
Now you need to phone the voicemail number you just got from the phone company. You will be prompted to enter your phone number and also your PIN. This will then log you into the system, after this it will be exactly the same as when using it from your cell phone.
You will be able to listen to, delete and reply to voicemail messages without needing to use your cell phone minutes.
 forum activity
