How to Choose a Toilet for Your Bathroom
what you'll need
- Pen and Paper
- Tape Measure
Choosing the best toilet for the bathroom is essential for one’s toileting comfort. As the best seat in the house, it has come to be known in many different names including the house of office, John, privy, crapper, and so much more. Here is how to choose the right toilet for your bathroom.
Step 1 – Determine the Toilet “Rough In”
The toilet rough in is the distance between the toilet’s rearmost bolt holes and the wall behind the toilet. Usually, this distance is 12-inches. However, this may vary. Some toilet models come in sizes of 10-inches and 14-inches. There are also instances when the toilet tank does not fit into the wall. In this case, a 10-inch rough in is needed. Measure the rough in size of the toilet and take it to the home improvement store when purchasing.
Step 2 – Determine Other Size Factors
One of the factors that need to be considered is whether to buy an elongated toilet or a round toilet. This will depend on the bathroom size of course. If the bathroom space is relatively smaller, consider buying a round toilet. If the bathroom space offers enough room, then an elongated toilet is okay. When it comes to comfort, elongated toilets are more preferred.
Step 3 – Consider the Height of the Bathroom
The usual height for toilets is 14-inches from the ground. These traditional toilets are best for a variety of people, especially when there are kids around. However, some toilets are designed to be slightly taller to provide ease when sitting and standing.
Step 4 – Choose the Flushing System
There are two different types of flushing systems to choose from. One uses the natural effects of gravity and one uses a pressurized system to flush down waste into the trap. The gravity-fed toilet flush system is the traditional way of flushing toilets. It uses gravity to pull water down the toilet bowl to flush the waste. However, some people want to have their wastes flushed speedily. There is no problem with that because the other type of flush system makes this possible. The pressurized toilet flush system makes use of an air compressor to pressurize the flushing mechanism. When the toilet flush button or lever is pushed, the compressor flushes water at high speeds to produce a speedy flush.
Step 5 – Choose the Toilet Style
Aside from choosing the right color for the toilet, one can also choose between three different toilet styles. There is the two-piece toilet style that has been used for generations, the one-piece toilet style that is a bit expensive but easier to clean, and the stylish wall-mounted-tank toilet that offers the best aesthetic value for a not-so-affordable price. Apparently, the two-piece toilet is the most sought after toilet because it is the most affordable. For a chic and fashionable house of office, consider choosing one of the many designs offered by the manufacturers of toilets with wall-mounted tanks.
