How to Choose a Wood Ceiling
Adding a wood ceiling to your room can add a touch of warmth and old world charm to your home. Wood is a great choice because you are able to stylize it any way you wish. Wood is also reasonably priced. Here are a few things that should help you choose your wood ceiling.
What Are Your Needs?
Wood may sound like a great idea, but what if your home stays more humid than most? Humidity can break down wood much more quickly. If you live in an area that has problems with termites, adding a wood ceiling can just exacerbate the problem. Consider these things before choosing a wood ceiling.
What Kind of Wood Should You Use?
While pine is the most common wood used in home applications, other kinds of wood can offer you a completely different look. Many people will use cypress for it’s unique appearance, or cherry for the dramatic look. Since you won’t be walking on the ceiling the wood doesn’t have to be able to take much abuse, so your options are wide open.
Should I Use Planks or Tiles?
Tiles are by far easier to deal with on ceilings than planks are. Tiles also offer you more design options. If you are wanting a very dramatic look then planks may be the best bet. But prepare for a lengthy and difficult installation process if you choose this.
