Login Error
Close
How to Choose the Best Washer and Dryer
by DoItYourself Staff
Today's washers and dryers come with so many different options that at times it can be confusing to the consumer to determine what exactly meets their needs. Because the laundry needs of any family are different, and so many styles are available today, it is wise to consider all the options available on the market. This article will discuss the many options, and help you to determine what will meet your needs.
Basically here are two types of washing machines - top loading and front loading. Each has its pros and cons. A top loader is not as energy efficient as a front loader. A front loader generally has a very long wash cycle. Let's look at the facts we need to determine our choice.
First, we should determine what we need in terms of capacity, water efficiency, energy efficiency, volume, length of wash cycle, programs, controls, and filtering systems.
Capacity should be your first consideration. Choose a machine that will meet the needs of your family. Most washers measure in kilograms. A machine that can handle 6-7 kg (10 lb approx.)is large enough for a family with a couple of children.
Water efficiency is measured by how efficient the machine is in terms of energy usage. Because each area of the country has different water usage figures, check with your local water utility to determine savings in your area. Again, a top loader is not as energy efficient as a front loader.
Volume is determined by the amount of noise a machine will make during the spin cycle. Obviously, you do not want a shrieking machine next to the family room.
Length of wash cycle is determined by the length of the washing cycle. If you are always on the run, you don't want a machine that takes forever to run a load. Here, front loaders come out the loser.
The programs available on a machine are the bells and whistles that you should determine whether or not you can live without. Many are available, such as spin speed, gentle cycles, and hand washing cycles. It helps to know how much you wish to interact with the machine. Some modern washers can determine the size of the load, the proper cycle to use, and even how dirty your laundry is.
Controls should be easy to understand and easy to reach. Old machines use knobs, newer touch type controls.
The filtering system strips lint away from your clothing as the machine washes. This is an issue with top loaders, so be careful to determine the quality of any filtering system on a top loader. Many front loaders do not have this system as a standard feature as it is not a problem like top loaders.
Let's look at the pros and cons of both a top loader and a front loader.
Top loader:
    Pros:
  • Usually cheaper than a typical front loader
  • Can add laundry during the wash cycle
  • A faster wash cycle
  • Lighter in weight
  • Large capacity washers are readily available
    Cons:
  • Less energy efficient than a front loader
  • Uses more water
  • Uses more laundry detergent per load
  • Harder on clothing
  • Increased ongoing cost
Front loader:
    Pros:
  • More energy efficient
  • Uses less detergent
  • A cleaner wash
  • Doesn't damage clothing like a top loader
  • Faster spin cycle, leading to shorter drying time
    Cons:
  • Higher initial cost over a top loader
  • Usually cannot add clothing during the wash cycle
  • Creases clothes more than a top loader
  • Much heavier than a top loader
Use these factors to determine what works the best for you and your family. If you live in an upper story apartment and are single, a top loader would suit you well. If you have a ground level laundry room and have a large family, consider a front loader.
All dryers do the same thing - they spin your clothing in a drum and dry them using a heat source. A real consideration for the budget conscious person is using a gas dryer, as they are more energy efficient. Dryers are rated by their capacity size, and choosing one that complements your washer capacity is a wise choice. For example, a 3.5 cubic foot washer would require a 7 cubic foot dryer capacity. Dryers come in sizes ranging from 5 to 7 cubic foot capacity.
Although dryers are a huge user of energy, new models are now available that has specialized options for drying clothing. Law states that a dryer must have at least one automatic cycle. However, you can opt for a dryer that has a cool down cycle, a moisture sensor that determines when to shut down, and a damp dry cycle. Dryers can be purchased that have a tumble free cycle for drying such things as sneakers or canvas shoes.
These simple guidelines can help you determine what works best for you. Consider all options when making this major purchase.
 forum activity
