Login Error
Close
How To Clean A Bathroom Fan
by DoItYourself Staff
what you'll need
  • Ladder
  • Mild Scrubber or Rag
  • Soap Water
  • Dry Cloth
The bathroom fan is usually the most neglected part of your house. As the bathroom is usually a fully enclosed room with little ventilation, the fan just keeps circulating the bad air in the room while it is operational, and collects dust on the outside when it is turned off. If you don't periodically clean your bathroom fan, it will develop residues of dust and potentially harmful bacteria.
Step 1: Make Appropriate Preparations
Don't clean the floor of the bathroom beforehand, since a lot of dust will fall on the floor and you will have to clean the bathroom again. Before cleaning the fan, please ensure that the power is switched off in order to avoid any sort of short circuiting or electrocution.
Step 2: Opening the Enclosure
Bathroom fans are typically enclosed in a plastic housing that is held together by simple clips, or by a few easy to access screws. You will need to undo the front cover of the fan to clean the louvers of the cover before being able to access the main fan blades themselves. Make sure you have the correct tools to do this.
Step 3: The Wet Cleaning Process
Take your piece of cloth or a duster to wipe the dust off the fan wings. When the dust is off the fan, then take your scrubber or a rag soaked in the soapy water. Wipe the fan with it till the dirt comes off. You might need to change your soap water in case it becomes very dirty by re-dipping the rag.
Step 4: Wiping off the Residue
Once you have cleaned the fan with the soapy water, take your dry cloth and wipe off all the excess dirt and water.
Step 5: Drying The Fan
Make sure no water or moisture remains on the fan as it may slip into the electric motor and cause short circuiting. It is always advisable to run your dry cloth over the fan a couple of times. Once you feel that the fan is dry, turn it on and that will further dry it.
Step 6: Wrapping Up
The last step is to attach the cover back onto the fan and clean up the remaining mess on the floor from the fan. You will see and feel the difference. You will feel that a clean fan gives a pleasant air and makes the bathroom look much cleaner.
 forum activity
