Login Error
Close
How to Clean a Humidifier with Vinegar
by DoItYourself Staff
what you'll need
  • Vinegar
  • Warm water
  • Empty spray bottle
  • Owner's manual
  • Sponge
  • Washcloth
  • Scrub brush
  • Expendable toothbrush
  • Faucet
If you own a home humidifier that has recently fallen prey to mold, mildew or mineral buildup, you'll want to know how to clean a humidifier. Although you will be required to clean this device at least once a week to ensure that it functions properly, you'll be pleased to learn that it can be cleaned with nothing more than common household vinegar and several other basic cleaning tools. Vinegar will effectively purge your humidifier of filth and make the aforementioned weekly cleanings a breeze.
Step 1 - Disassemble Your Humidifier
When considering how to clean a humidifier, the first step is to unplug the device and take it apart in preparation for the cleaning. Begin by shutting off the humidifier and subsequently unplugging it. Next, using your humidifier's owner's manual as a guide, proceed to take the device apart, starting with the tank. Once the tank has been safely detached, proceed to remove the humidifier's filter in the manner specified in your owner's manual. If your humidifier features a detachable motor, take care to remove that, too. Although the execution of this step will vary depending on the brand and model of your humidifier, it should not require the aid of any tools. If you've misplaced the device's owner's manual, you can generally find comprehensive disassembly instructions online.
Step 2 - Scrub the Tank
The next step in how to clean a humidifier involves giving the device's tank a good scrubbing. Start this step by combining 1 cup of vinegar with 1 cup of warm water in an empty spray bottle. Next, remove the tank's cap, empty the tank into one of your home's drains, then proceed to apply your newly formed cleaning solution to the inside of the tank. Allow the solution to sit for a minute or so, then use a sponge, washcloth, scrub brush or toothbrush to scrub away any dirt or mineral deposits. Repeat this process on the tank's exterior before rinsing and subsequently refilling the freshly cleaned tank.
Step 3 - Clean Your Humidifier's Filter and Base
Having thoroughly cleaned your tank, you've completed the most laborious part of the cleaning process. The third step in how to clean a humidifier will essentially require you to soak the device's filter and and gently scrub its base. Begin by placing your humidifier's filter in a sink or bowl filled with a mixture of water and white wine vinegar and allow it to sit for 45 minutes to an hour. Next, pour a small amount of vinegar into the device's base and allow it to sit for the previously specified amount of time. After the parts have been given ample soaking time, use a sponge, washcloth, scrub brush or toothbrush to remove any remaining bits of filth or mineral residue. Follow up by giving both parts a thorough rinsing and make sure they are completely dry before proceeding to reassemble your humidifier.
With these three helpful steps at your disposal, you'll never again be unclear on how to clean a humidifier.
 forum activity
