How to Clean a Limestone Floor
what you'll need
- Broom
- Dustpan
- Stone cleaner
- Mop
- Bucket
Installing a limestone floor in your home can provide you with a very beautiful and durable flooring option. However, in order to keep it looking good, you need to make sure that you clean it properly. Here are a few tips on how to clean a limestone floor.
Step 1: Regular Sweeping
In order to maintain your limestone floor, you will want to sweep it regularly. Use a broom and a dustpan to remove any excess dirt or dust from the surface of the limestone. Do this as often as you can.
Step 2: Mop the Floor
You will most likely want to mop the floor occasionally as well. You can start out with using warm water to mop the floor. This will help you remove any excess dirt or dust that is left over after sweeping.
Step 3: Stone Cleaner
In order to deep clean the limestone flooring, you may want to use something a little stronger than water. There are a number of different commercially available stone cleaners that you can utilize here. Most of them can be mixed in with water and mopped onto the floor. Just make sure that you are dealing with a cleaner that is designed for stone surfaces.
