Login Error
Close
How to Clean a Sanding Sponge
by DoItYourself Staff
what you'll need
  • Water
  • Sink
  • Trashcan
  • Soap or any other alkaline solution
A sanding sponge is an extremely useful tool to keep around your workshop or home. It helps in smoothing rough surfaces and also aid in cleaning almost any place that is dusty and needs to be smoothed or unsoiled. A sanding sponge has the quality of scrubbing corners, dirty edges, drywall and other areas. It is highly flexible and can be used on flat as well as on contoured surfaces. A sanding sponge can be used for multiple cleaning purposes and needs to be cleaned from time to time as the dust can attach to the sponge and make it less effective. The biggest advantage of using a sanding sponge is that it can be washed to remove the clogged material. This makes it very long lasting. Cleaning the sponge is easy and should be done after each use. It approximately takes five minutes, and you are done. Follow the simple steps described below in order to clean a sanding sponge.
Step 1 – Removing Dust from Sanding Sponge
Take the sanding sponge full of dust to your trash can. Use your fingers and try to dust away the dirt on the upper layer of the sanding sponge. This will help the dry dust to go off, that would otherwise stick to the sponge if rinsed with water immediately after being used to clean a dusty appliance. Repeat the dusting process until the sanding sponge is free of the dry dirt on it.
Step 2 – Using Detergent
Take the sanding sponge to the sink and pour warm water on it until it’s completely wet. The warm water will make the washing process easy as it will not allow the dirt to stick on the sponge. Use any alkaline solution such as soap or any other cleaning detergent and softly rub your fingertips on the sponge surface and clean the residue left on the sponge’s surface. Repeat the procedure until the dust residue is all removed from the sanding sponge. The solution will also provide the sponge with a pleasant fragrance that would be helpful if the sponge has some unpleasant smell. It would be hygienic to use a detergent as it will aid in killing germs and other bacteria that come along with mud and debris.
Step 3 – Drying the Sponge
Squeeze the sanding sponge so that all the water gets drained and then put the sanding sponge in the sunlight or allow the sanding sponge to air dry. After the sponge is dry, it is ready for cleaning up effectively. The sanding sponge can be used in both the forms; dry or wet. It is effective either way. A wet sanding sponge can be more suitable for certain appliances and the dry sanding sponge will be suitable to collect dust and debris.
 forum activity
