How to Clean a Water Stain From Bricks
what you'll need
- White wine vinegar
- Spray bottle
- Water
- Garden hose
- Hard-bristled scrub brush
If you have any brick surfaces in your home that have incurred water stains, you should familiarize yourself with how to remove a water stain from bricks. In just a few easy steps, you'll be able to successfully clean a water stain from bricks.
Step 1 - Apply Your Vinegar
White wine vinegar is a surprisingly effective tool in purging a water stain from bricks. Begin the stain removal process by pouring some white wine vinegar into a clean empty spray bottle. Next, vigorously apply the vinegar to the water-stained area of your brick surface. After allowing the vinegar to sit for 15 to 20 minutes, you'll be ready for the next step.
Step 2 - Scrub the Water Stain
Now that your vinegar has had enough time to penetrate the water stain, you will need to use a hard-bristled scrub brush to thoroughly scrub the stained area. If the water stain proves unyielding, you may need to apply some more vinegar. Keep in mind that getting rid of a water stain that has had a good deal of time to set will require a substantial amount of elbow grease. Once the stain has been removed, use a garden hose to rinse any remaining vinegar from the freshly cleaned area.
