Login Error
Close
How to Clean Air Conditioner Filters
by DoItYourself Staff
what you'll need
  • Vacuum
  • Small basin
  • Screw driver
  • Vinegar
  • Rag
  • Old towel
It is important that you know how to clean air conditioner filters in your home or office. This will make a big difference to the quality of air you breathe when indoors. Regular cleaning will also help improve the efficiency of your air conditioner and keep it in good shape for longer. It is easy to forget about periodic cleaning that is necessary to ensure a healthier breathing environment. Think about the accumulation of dirt, pathogens and allergens on the filters with constant use. The filters serve to keep the air conditioner components clean which helps to create a clean environment indoors. Regular cleaning is important in maintaining healthy air. It is a good idea to clean often rather than wait until the filter is filled with dust before you clean. A good cleaning is recommended at least twice a month and should be one that involves more than just running the filters under water. Following is a simple guide that will get your filters clean and help maintain a healthy living environment.
Step 1 - Open the Air Conditioner
Make sure your air conditioner is turned off at the mains. Carefully remove the air conditioner components apart. You may have to use a screw driver to dislodge fitted screws.
Step 2 - Remove Filters
Remove the filters from the air conditioner. It is a good idea to inspect them for any wear and tear effects. If you spot any rips or snags you are better off replacing the filters as to continue using them when worn out will hamper efficiency.
Step 3 - Vacuum
Use a vacuum to get rid off all accumulated dirt and grime. Be as thorough as you can for effective cleaning results.
Step 4 - Sanitize the Filters
Fill a basin with equal portions of water and vinegar. Make sure that you create enough of this solution so that the filters are totally submerged when placed inside. The vinegar will kill harmful bacteria and allergens that may have accumulated in the filters.
Step 5 - Soak
Allow the filters adequate time to soak in the cleaning solution. If you have not cleaned the filters recently, leave them for about 4 hours to get properly sanitized. However, if the filters have only been used moderately or have been recently cleaned, soak for 1 hour.
Step 6 - Drain
Remove the filters from the cleaning solution and allow the mixture to drain off. Do not rinse the filters as to do so will reverse the effects of the sanitizing process. You can place them onto an old towel so that any excess solution is absorbed by the towel.
Step 7 - Dry
Allow the filters to dry naturally while still on the towel. It is best to place the towel outside in the yard or wherever some sunshine is available to facilitate effective drying.
Step 8 - Fit the Filters
Fit back the filters into the air conditioner and replace the air conditioner components. You can now enjoy cleaner, more breathable air.
 forum activity
