Login Error
Close
How to Clean Air Conditioner Mold
by DoItYourself Staff
While a clean air conditioner may help to clear airborne allergens from a room or home, air conditioners themselves can negatively impact those who suffer from atopic allergies. Due to the moist, warm conditions, the inside of an air conditioner is a prime breeding ground for mold and other bacteria. Follow these appliance tips for cleaning mold from your air conditioner, and keep the air in your home clean and free of allergens.
How Mold Grows in an Air Conditioner
Mold spores float through the air in even the most sanitary environments. However, these spores must find favorable conditions in order to attach and reproduce. Most allergy sufferers who are susceptible to mold experience particularly strong reactions in areas with actively growing mold spores.
Air conditioners, if kept unclean, may serve as suitable breeding areas for mold spores. As the condenser in an air conditioner cools the air, it draws moisture from the atmosphere. While this effectively controls humidity in a room, it also creates an especially damp local environment for mold.
Cleaning Mold from Your Air Conditioner
Cleaning mold from your air conditioner is a simple process. However, it requires some special supplies. Before you begin cleaning your air conditioner, gather a vacuum cleaner, a long brush, de-greasing cleaner and cloths or rags. You will also need a container for waste.  Follow these steps to clean the mold from your conditioner:
Step 1 – Remove the Plate Filter
Using a screwdriver, remove the front plate filter from the air conditioner system. You may wish to clean the filter with dish or laundry detergent and water. Simply allow the filter to soak in a small pan of diluted detergent.
Step 2 – Remove the Plate
Having removed the filter from the front of the plate on the air conditioner, proceed by removing the grill plate itself. Continue by removing any other metal coverings, exposing the inside of the central air conditioner.
Step 3 – Brush and Vacuum the Inside of the Air Conditioner
Using your brush and rags, clean the dust from the inside of the air conditioner system. Ensure that you remove dirt from every crevice inside of the system. Be careful not to break the delicate pieces inside of the air conditioner.
Continue by de-greasing the inside of the air conditioner. Allow the de-greaser to stand for 15 to 20 minutes before gently washing the inner pieces with warm water. Ensure that water does not come in contact with any of the electrical workings.
Step 4 – Vacuum and Drain Excess Water
Before returning the front plate and filter to the air conditioner, carefully vacuum the inside of the air conditioner system to remove any remaining dirt and mold spores. Using a cloth or towel, soak up any excess water that may be left over from the de-greasing portion of the cleaning procedure.
Step 5 – Reinstall the Plate and Test the System
Carefully ensure that all pieces of the system are not bent or broken, and then reinstall the front plate. Test your air conditioner to ensure that it runs smoothly and without loud noises.
In order to best protect the quality of the air in your home, perform this mold cleaning procedure about once per year. This will not only serve to improve your overall health, but it will also prolong the life of your air conditioner considerably.
 forum activity
