cancel
Job type :
Zip Code :
community forums
comments
How To Clean An Alcohol Stove
An alcohol stove is a good tool to have on hand in an emergency situation. The fuel that is used in an alcohol stove burns less hot than other fuels, it's portability and small size makes if perfect for camping and backpacking.  Cleaning your alcohol stove is the best way to keep it working well.
Cleaning the Alcohol Stove
Because the stove burns less hot than other types of fuel, it is important that you keep the burners clean to avoid anything that will lessen the heat  further. Cleaning the surface of the stove after every use will remove any excess debris on the surface. Use a damp cloth to wipe down the stove before you put it away after you use it.
Maintenance
Along with cleaning your alcohol stove, you should check the parts on the device to be sure that everything is working properly. To avoid any problems from occurring when you really need the stove, you should perform your maintenance checks regularly. Before heading out to a camping trip, test the stove so you don’t end up with a faulty cooking device while you are far from home.
member comments
Did-it-myself Projects
updated by gibburnz
did this on 11/23/2009
Small Kitchen Rental Upgrade
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by dhammon
did this on 11/04/2009
The Deck
Decorating For Thanksgiving
sponsored articles of the day
