How to Clean and Maintain Oak Parquet Flooring
Oak parquet flooring can provide you with a classic look that many people love. This type of flooring has been popular for decades and it is still relevant today. In order to keep the floor looking its best, you want to clean it and maintain it properly. Here are the basics of how to clean and maintain oak parquet flooring.
Remove Dirt
As part of your regular cleaning schedule, you will want to thoroughly remove any dirt from the surface of the parquet. You can do this by using a broom and a dustpan or a vacuum cleaner. Regardless of which method you use, you should plan on removing the dirt approximately once a week if not more often. Dirt is a very corrosive substance and it can affect the parquet negatively. If you allow dirt to remain on the floor, it is going to look old very quickly.
Deep Cleaning
Every now and then, you will want to engage in some deep cleaning with your parquet floor. When you do this, you will not want to wet mop the floor like you would with tile or vinyl. If you get too much water on the floor, it could potentially start to warp and buckle. Water and wood flooring do not go well together, so never let water sit on the floor.
You can use certain cleaners on this type of floor. There are a number of wood floor cleaners that are specifically designed to clean wood flooring without damaging the finish. Check with the manufacturer of your flooring to see if they have any specific cleaners that they would recommend. When using these cleaners, you will want to spray them on and then wipe them up quickly. You can use a dry mop to clean them up if you want.
Avoid Harsh Chemicals
When cleaning your floor, you will want to do your best to avoid harsh chemicals. For example, if you get bleach on your flooring, it can discolor the parquet. Because of this, you will want to read the ingredients on any cleaner that you purchase for the floor.
Finish
If your parquet flooring was finished on-site, you may need to periodically add another coat of finish to the floor. Polyurethane finish has a tendency to wear off after a certain period of time. With continuous traffic walking on the floor, it will wear off underfoot. In this case, you will need to get some more polyurethane finish and apply it to the surface of the floor. You will need to remove everything from the room and apply the polyurethane with a rag. Make sure that you ventilate the room when you are doing this because polyurethane will let off some dangerous fumes that can hurt you.
