How to Clean Barbecue Grill Grates Easily
what you'll need
- Wire brush
- Grill stone
- Tin foil
Cooking on a barbecue grill can be a very rewarding experience. However, when it comes time to clean the grill grates after you are done, it might not seem as enjoyable. Here are the basics of how to clean barbecue grill grates easily and effectively.
Step 1 - Wire Brush
Using a wire brush periodically will help you remove most of the build up on your grill grate. These wire brushes are widely available wherever you can get grilling supplies. This can be done before or after you heat up the grill.
Step 2 - Grill Stone
Another option that you have for cleaning the grill grate is to use a grill stone. This is traditionally a pumice stone that you can use to rub against the grill grate. This is great at breaking down the hard build up that gets on your grill.
Step 3 - Tin Foil
Perhaps the easiest way to clean your grill grate is to utilize tin foil. Start out by wrapping the grill grate completely with tin foil when the grill is still cool. Then, turn on your grill and heat it up. Leave the grill running for 30 minutes to 1 hour. At that point, you can remove the tin foil and your grill should be completely clean.
