How to Clean Brass That Is Stained
what you'll need
- Lemon juice
- Table salt
- Warm water
- Spray bottle
- Washcloth
- Scrub brush
If you've been looking for an effective way to clean brass stains, you should know that common lemon juice and table salt can make a highly potent brass stain remover. Below are the steps you'll need to take to remove stains from any brass items in your home.
Step 1 - Mix Your Cleaning Solution
Before getting rid of any stains, you will need to create an easy-to-make homemade cleaning solution. Begin this step by acquiring an empty spray bottle in which to combine:
- 1 tbsp lemon juice
- 1 tsp table salt
- ½ cup warm water
Once the ingredients have been combined, securely seal the spray bottle and apply the cleaner to any stained areas of the brass item you wish to clean.
Step 2 - Clean the Brass Stains
Now that you've mixed your cleaner, use your spray bottle to apply it to the stains. Once the cleaner has been applied, allow it to set in for about 10 minutes, as its acidic nature will help life and break apart the stains, ultimately making it easier for them to wipe off.
Next, depending on how stubborn the stains are, use either a washcloth or a scrub brush to purge them from your brass item. Lastly, rinse all remaining traces of your cleaning solution off the clean brass underneath a faucet.
