Login Error
Close
How to Clean Cedar Chests
by DoItYourself Staff
what you'll need
  • Vacuum with soft bristle attachment
  • Dust cloth
  • Fine grit sandpaper
  • Cedar wood oil
  • Clean rags
Cedar chests are attractive pieces of furniture customarily used to store heirlooms, quilts and anything you want to protect. Over time, the fragrant cedar smell dissipates, though you can restore it through cleaning. Follow the simple steps below to clean a cedar chest on your own.
Step 1: Remove Loose Particles and Debris
With a hose vacuum and a soft bristle attachment, go over the entire inner area of the cedar chest, sucking up any loose particles.
Step 2: Wipe Chest Down and Air it Out
Use clean, dry dust rag to follow up the vacuuming by thoroughly wiping down the chest. Allow the chest to aerate for half a day by letting it sit with its lid open in a well-ventilated area.
Step 3: Restore the Fragrance
Using light circular motions, gently sand the interior of the chest with very fine grit sandpaper. The intent is not to smooth rough edges, but to release the aroma of the cedar by removing a very thin layer of wood.
Step 4: Apply Oil
Wipe the chest down again to remove all dust, and carefully rub in a light layer of cedar wood oil to restore the glow of the wood and protect it from the elements.
 forum activity
