How to Clean Chest Freezer Condenser Coils
what you'll need
- Replacement Condenser Coil
- Screwdrivers
- Torchlight
- Vacuum Cleaner
- Brush
Every year owners of chest freezers should clean the condenser coils so that the freezer can run more efficiently. In standard freezers, the condenser coil is a static condenser which runs up and down behind the freezer which can be vacuumed or cleaned with an unused cloth.
In a simple freezer circuit, there are two sets of coils including the evaporator and condenser coils. Both condenser coils are filled with gas and liquids and belong to the circuit where the compressor and expansion valve perform the job. The evaporator coil is the copper pipe that is joined to the condenser coil. It is located in a cool space and functions to absorb heat from the space. The heat will pass through the cool space where some of the heat is released into the atmosphere. The suction of the compressor draws the cool liquid to the expansion valve where the liquid boils off to a gas. At this stage, the gas temperature will decrease in the evaporator coil. In this way, the process will keep reiterating until the thermostat is satisfied. Due to the fact that the condenser coil is exposed to the ambient air, it must be frequently cleaned.
Step 1: Disconnect all Plugs
First, it is necessary to disconnect the plugs from the freezer including the circuit breaker. Once the circuit breaker is shut, you can remove the fuse and slide the freezer away to unplug the freezer’s plug from the switch outlet. If the freezer has an ice maker, turn off the water supply lines.
Step 2: Locate the Condenser Coils
In older freezers, the condenser coil runs up and down at the back. The coil is often painted black and resembles a grid like structure. In modern freezers, the condenser coil is located underneath. There is a face that is directed at the condenser coil to help cool down the heat. Use a torchlight to locate the coil and fan. If the condenser coil is located behind the toe space panel, you will have to remove the panel and condensate tray to reveal the flat condenser coil. If the condenser coil is on the rear access panel, slide the freezer away and remove the screws that hold the panels to reveal the cylindrical condenser coil.
Step 3: Vacuum the Dirt and Dust
Use a vacuum cleaner to clean away the dirt and dust on the condenser coil. When cleaning, make sure not to damage the coil. If the coil is accidentally broken, the refrigerant will escape which can be costly to repair.
Step 4: Vacuum the Freezer Fan
If the freezer pan is accessible, vacuum it to help move the air across the condenser coil. The dirt and dust that accumulate on the fan can hinder the airflow and damage the compressor.
Step 5: Remove the Remaining Dust with a Brush
If there is still any remaining dust on the coil and fan, gently brush it away with a paint brush.
The condenser coil should be cleaned at least two times per year. Before cleaning the freezer, always remember to unplug the power supply.
