Login Error
Close
How to Clean Mildew from Suede
by DoItYourself Staff
what you'll need
  • A scrub brush
  • A vacuum
  • A bowl
  • Petroleum jelly
  • Rubbing alcohol
  • A sponge
  • Cleaning cloths
  • A suede brush
  • A hair dryer
It is possible to clean mildew from suede. It is best to begin the cleaning process as soon as you find any evidence of mildew on the fabric. The sooner you get to the mildew, the less chance there is for the mildew to grow into a larger spot that will damage the suede. Suede is a fragile fabric. The porous nature of suede requires a special cleaning solution and a gentle cleaning process, in order to properly remove the mildew from the fabric.
Step 1 – Brushing Away Mildew Spores
Take the suede to a protected outdoor area. Be sure you do this on a day with good weather. Use your scrub brush to gently brush away the mildew spores on the suede.
Step 2 – Vacuuming the Suede
Take the suede back indoors. Use your vacuum to remove as many of the remaining spores as possible. Carefully suction the mildew area on the suede. Remove the bag from the vacuum. Place the used vacuum bag in a garbage. Close and secure the opening of the bag. Dispose of it immediately in a proper disposal container.
Step 3 – Applying Petroleum Jelly
Apply a small amount of petroleum jelly to one of your cleaning cloths. Use the cloth to rub the petroleum jelly into the mildew area on the suede.
Step 4 – Sponging the Mildew Area
In a bowl, combine equal parts of rubbing alcohol and warm water. Immerse your sponge into the solution. Squeeze out any excess liquid. Use the sponge to dab the solution onto the mildew area of the suede. Continue applying the solution until the entire mildew area has been removed.
Step 5 – Blotting the Suede
Use soft, clean cloths to blot any excess water from the suede. Lay a cloth onto a flat surface. Place the suede on top of the cloth. Lay another soft cloth over the suede. Apply pressure to the cloth, to draw the moisture out of the suede and into the cloth. Continue the process, until the cloth is unable to draw out any more moisture.
Step 6 – Drying the Suede
Use a hair dryer to dry any remaining moisture in the suede. Be sure the hair dryer is turned to the off position before you begin. Hold the dryer at least 1 foot away from the suede to prevent any burns or shrinkage to the fabric. Set the hair dryer to the lowest possible heat level. Turn on the hair dryer and allow the air to dry the suede.
Step 7 – Brushing the Suede
When the suede is completely dry, brush it to restore the nap to the fabric. Use your suede brush to carefully brush the nap. Be sure to use long, even strokes. Work the brush in the same direction over the fabric, to achieve the best possible results.
 forum activity
