Login Error
Close
How to Clean Mildew off a Bathroom Ceiling
by DoItYourself Staff
what you'll need
  • Commercial mildew cleaner
  • Stepladder
  • Mop
  • Sponge
  • Scrub brush
  • Washcloth
  • Toothbrush
  • Safety goggles
  • Breathing mask
If your bathroom is prone to mildew infestation, you may be curious about how to clean mildew off the ceiling. If so, you'll be pleased to learn that cleaning a mildew-laden ceiling can be a very simple task.
Step 1 - Make Your Preparations
Before proceeding to clean mildew from your bathroom ceiling, you will need to make a few preparations. First off, make sure you have a stepladder that is tall enough to give you comfortable access to your bathroom ceiling. Secondly, make sure to open your bathroom door and windows to ensure proper ventilation. This will help protect you from the adverse effects of prolonged exposure to the fumes emitted by the commercial mildew cleaner you'll be using. Lastly, take care to don a pair of safety goggles and possibly even a breathing mask, as dripping is sure to occur whenever a cleaning solution is applied to a ceiling.
Step 2 - Apply Your Cleaner
Having made the necessary preparations, you are ready to apply your cleaner. Elevating yourself with the aid of your stepladder, vigorously spray your cleaner onto any mildew-infested areas. After applying your cleaner, make an effort to steer clear of any dripping. Once the cleaner has had several minutes to set in, you'll be ready to proceed with the next step.
Step 3 - Scrub Your Ceiling
Now that your cleaner has had ample time to sit, you are ready to clean the mildew. For most types of mildew, this task can be performed with the aid of a sponge or washcloth. If the mildew is particularly stubborn, you may need to use a hard-bristled scrub brush to successfully purge it. Additionally, if the mildew has found its way into the spaces between your ceiling tiles, an expendable toothbrush can be a surprisingly effective tool in scrubbing it away.
If the idea of standing on a stepladder for an extended period of time doesn't appeal to you, you can stand on the floor and use a long-handled mop to clean mildew off your bathroom ceiling. Assuming your mildew deposits aren't very stubborn, this handy cleaning tool should adequately remove them from your ceiling.
When cleaning mildew, make a point of taking periodic breaks, especially if you feel yourself becoming overwhelmed by the cleaner fumes. It is recommended that you take these breaks outdoors, as fresh air offers a refreshing contrast to the fumes emitted by most commercial cleaning products.
Step 4 - Apply Your Finishing Touches
Once you've gotten rid of your ceiling-based mildew deposits, you'll need to dry the ceiling with the aid of a clean cloth. Moisture and dampness are among the leading causes of mildew formation, so when performing this step, be as thorough as possible.
To prevent future mildew infestation, make sure your bathroom is properly ventilated. This is usually a simple matter of installing a window-mounted electric fan in one of your bathroom windows and leaving the bathroom door open whenever your shower is in use.
 forum activity
