Login Error
Close
How to Clean Motorcycle Exhaust Pipes
by DoItYourself Staff
what you'll need
  • Commercial metal cleaner
  • Metal polish
  • Scrub brush
  • Scrubbing pad
  • Rubbing pad
  • Washcloth
  • Sponge
  • Empty spray bottle
  • Water
If your motorcycle exhaust pipes have accumulated a noticeable amount of dirt and debris, you may be curious about how to clean them. Fortunately, cleaning a motorcycle's exhaust pipes is a job anyone can tackle with a few easily obtainable tools.
Step 1 - Apply Your Metal Cleaner
Begin the cleaning process by spraying your motorcycle exhaust pipes with a commercial metal cleaner. When purchasing your cleaning solution, make a point of selecting one designed for use with the type of metal of which your exhaust pipes are composed. After allowing the cleaner to set in for several minutes, use a scrubbing pad, scrub brush, washcloth or sponge to wipe the pipes clean.
Step 2 - Rinse Your Pipes
Having given your motorcycle exhaust pipes a thorough scrubbing, you're ready to rinse them. Use a dampened washcloth or a water-filled spray bottle to wipe away all traces of your cleaning solution. Once you have sufficiently rinsed the pipes, use a clean cloth to dry the pipes.
Step 3 - Apply Your Metal Polish
Finally, use a soft cloth or rubbing pad to apply polish to your pipes. As was the case when selecting a cleaner, make sure the polish is designed to be used in conjunction with the type of metal of which your exhaust pipes are composed.
 forum activity
