cancel
Job type :
Zip Code :
community forums
comments
How to Clean Out Your Metal Gutters
A common problem with metal gutters is that they fill with leaves and other debris, preventing water from draining through them properly. A gutter full of leaves in the wintertime can cause problems by trapping snow and ice in place and ruining the wood of the fascia. Cleaning your gutters can prevent these problems.
Remove Debris
A leaf scoop is a good tool for removing leaves and debris from metal gutters manually. A pressure washer, however, can be used to blast debris out without the need for climbing and standing on a ladder to clean them. This is a messier option, so you may want to remove solid debris first. If you use a leaf scoop rather than a pressure washer, once you've removed the solid debris use a hose to rinse the gutters clean.
Downspouts
Be sure the downspout is draining properly and that there's nothing stopping the water flow. Leaves can clog this part of your system, too. You can use a hose to try to clean it out or a pressure washer. For serious clogs, a plumbing snake can help break them free. Remove the downspout from the metal gutters for stubborn clogs so you can see more clearly into the tube.
member comments
Related Articles
How to Solder
Follow these tips and instructions on how to work with solder to help you save... read more
How to Build Seamless Gutters
Seamless gutters are a great addition to any home, and increase the value to you... read more
Tales from the GutterTales from the Gutter
Some information on pros and cons of different gutter types and materials, as well as... read more
articles we like
Canning Vegetables
Canning vegetables is a simple way of storing freshness and taste. If you are able... read more
Magnificent Minestrone Soup
Minestrone soup is a thick, delicious, and filling dish. It is quick and fairly easy... read more
An Easy Way to Save on Auto InsuranceAn Easy Way to Save on Auto Insurance
Every year the cost of owning a vehicle seems go up. Expensive repairs, maintenance, fluctuating... read more
sponsored articles of the day
diy centers
