Login Error
Close
How to Clean Paint Stains Off of Clothing
by DoItYourself Staff
what you'll need
  • Paint stained clothing
  • Emulsifying solution such as alcohol or hand sanitizer
If you’ve ever painted your house or room, you know how hard removing paint stains from clothing can be. Rather than give up on stained clothing, try some of the methods below to effectively remove latex paint from your clothing.
Step 1: Remove Initial Layers of Paint
If there is an abundance of dried latex paint on your clothing, you can use a very strong tape to peel the initial layers of paint off your clothes. Types of tapes that you can use include gaffer’s tape, extra strong duct tape, or high speed body repair tape. Apply enough tape to cover the whole latex paint stain and quickly peel it off, removing the paint with the tape.
Step 2: Emulsify the Stain
Paint removal is best accomplished when you emulsify the latex that is the binder for the paint. A substance that works as an emulsifier will break up the material that is causing the stain and cause it to be suspended in solution with the emulsifier. You can use either hair spray or isopropyl alcohol as an emulsifier. Other products that work quite well as an emulsifying paint cleaner are listed below:
  • Hand sanitizer products
  • Goof off
  • Cleanser
Step 3: Rub Briskly
This is one occasion in which to remove a stain you will want to rub. In order to assist the emulfier in removing the stain, you should use a fingernail to scrub the stained area until the stain is loosened. Many people have found that using an implement such as a butter knife to scrape at the stain to loosen it and allow the alcohol to act works quite well.
Step 4: Wash Normally
Once you have briskly rubbed or scrubbed that stained area with the alcohol soaking the clothing, you need to throw it into the washing machine and wash it as normal. You will need to get the piece of clothing into the washing machine as soon after finishing your scrubbing with the emulsifier as possible, otherwise the paint will be able to dry before being washed out and you will have to go through these steps all over again.
What Won’t Work
One of the actions that helps the most for loosening up a paint stain is scrubbing. Hard objects such as butter knives, fingernails and the edges of spoons work great for this. Scrub brushes and old toothbrushes don’t have the required stiffness that is needed to scratch and soften the surface of the latex paint causing the stain.
Test for Color Fastness
As always when using chemicals on clothing materials, you should check a small out of the way portion of the garment to make sure your chosen emulsifier doesn’t lift the color from the fabric along with the paint.
Whether you’ve just recently gotten some paint on a valued piece of clothing or the paint’s been there and been dry for awhile, removing that paint is much easier than most people think if you just know how. The preceding paragraphs have given you the information you need to remove that paint stain from your clothing.
 forum activity
