Login Error
Close
How to Clean Polypropylene Rugs
by DoItYourself Staff
what you'll need
  • Clean, white cotton rags
  • Vacuum
  • Putty knife
  • Liquid dish soap
  • Water
  • Bucket
  • Sponge
  • Scrub brush (on broom handle)
  • All-purpose cleaner (409, Fantastic, etc.)
Polypropylene rugs are often used as runners and protection for wood flooring because they retain their colors so well and are easily maintained. Routine vacuuming of the rug is strongly advised to keep dirt from grinding into the fibers. Keep in mind that after cleaning your rug, if there is any soap residue, it will attract dirt. The same is true if you are tempted to use fabric softener.
Step 1 - Vacuum
Be sure to maintain your polypropylene rugs by vacuuming on a regular basis to keep dust and debris from getting ground into the fibers. If the rug has spots that need additional care, begin with spot cleaning.
Step 2 - Spot Cleaning
If possible, blot the stain immediately with a clean, dry white cotton rag. If necessary, use a putty knife (butter knife) to scrape off any food or other stuck-on debris from rug. Vacuum once again to remove scraped debris.
Step 3 - Clean Spot
In a bucket, mix a small amount (1 to 2 tsp.) of liquid dish detergent with 1cup of cold water. Rub the stain with a sponge wet with the soapy water. Blot the area with a clean white dry rag.
Step 4 - Cleaning Entire Rug
If the entire rug needs cleaning, after vacuuming the rug, place it outside on a concrete surface (preferably sloped). Hose down the rug, wetting it thoroughly; either spray entire surface with cleaner (409 or Fantastic) or pour liquid soap directly onto the surface. With a scrub brush, work the cleaner/soap into the carpet. Rinse rug thoroughly with hose, until water runs clear. Lay rug on a flat surface to dry, turning frequently (if you have a strong enough clothesline, lay the rug over line). Alternatively, take your polypropylene rugs to a professional dry cleaner.
 forum activity
