Login Error
Close
How to Clean Silver Plated Objects That Have Tarnished
by DoItYourself Staff
what you'll need
  • Shallow dish
  • Aluminum foil
  • Salt
  • Baking soda
  • Clean towel
Learning how to clean silver plated objects can be a fun and easy task. Silver plated objects are usually subject to tarnish over time. Tarnish is a slower form of rust and leaves black spots on the silver objects. The silver plated object can then loose its smooth texture and can lose its shine, looking dull. Cleaning them the right way can bring back their smooth texture and the shine in minutes. Follow this step-by-step guide for help on cleaning silver plated objects that have tarnished. The tools and materials required for the job are given below.
Step 1 – Prepare the Silverware
The first step is to prepare the silverware for cleaning. Place the silver plated objects in a dish that is lined with aluminum foil. Make sure the objects are spread apart and are not lying on top of each other. When you have assembled them, sprinkle baking soda over them.
Step  2 – Boil Water
Boil water in a pan. The water should be enough to cover the silver objects that you wish to clean. When the water is boiling, add a pinch of salt to it. Then pour the water over the objects that are lined in the dish. Move the objects around in the water with a spoon. Use a wooden spoon. You will notice that the tarnish will start disappearing already.
Step 3 – Finish the Job
Allow the silver plated objects to sit in the boiling water for approximately 10 minutes or until all the tarnish has disappeared. Then allow the objects to cool down and take them out onto a clean dry towel. When they are dry, buff them with a clean dry cloth to get back the smooth texture and the shine.
 forum activity
