Login Error
Close
How to Clean Soap Scum from Glass Shower Doors
by DoItYourself Staff
what you'll need
  • Scouring pad
  • Rag
  • Vinegar
  • Spray bottle
  • Lemon
  • Razor blade or scraper
  • Lemon oil or furniture polish
  • Dryer sheets
  • Squeegee
You may encounter difficulty when you try to remove soap scum from your glass shower doors, especially if the scum has built up over a long period of time. Having a large family makes it difficult to keep up with too. To thoroughly clean your glass shower doors and keep them clean, follow these steps.
Step 1 - Clean Edges and Corners
The edges and corners are the hardest places for you to remove soap scum. Fill your spray bottle with full-strength vinegar and slice the lemon in half. Spray vinegar around the edges of your glass shower doors. Next take half of your lemon and rub it around the edges of your doors. Concentrate on the corners.
The acid in the vinegar and lemon should melt any soap scum. If the scum is stubborn, let the solution sit for half an hour, and it will loosen. Carefully take a razor blade or other scraping utensil and remove the loosened soap scum. Scrub the glass shower doors with a scouring pad and rinse them. If all of the soap scum did not come off, repeat the process. Most often, one treatment will remove it all.
Step 2 - Clean the Doors
Spray the entire door with vinegar. Be sure you saturate the entire door well, especially at the top. The bottom will get a good soaking as the solution runs down. Using a dryer sheet, wipe down the entire area. Be sure your dryer sheet is not wet when you start. You may need a few sheets to completely clean the doors. If you notice some stubborn spots, use the other half of lemon to rub them clean. Then rinse the glass shower doors.
After cleaning the doors thoroughly, you can follow some tips to cut down on future cleaning and prevent the build-up from forming again.
Step 3 - Protect Your Glass Shower Doors
To protect your glass shower doors and make them shine, rub lemon oil on them and rub with a dry rag. The lemon oil removes any leftover debris from your doors and also polishes them. Be sure to remove all of the oil. As an alternative, you can use spray furniture polish. However, it will not work as well as the lemon oil.
For a weekly cleaning, leave the spray bottle of vinegar in the shower to give it a quick spray once a week. After showering, use a squeegee. After using the squeegee, leave the doors open to circulate air into the shower. These two tasks should keep your cleaning to a minimum.
 forum activity
