Login Error
Close
How to Clean Soap Scum Off Your Shower Mirror
by DoItYourself Staff
what you'll need
  • Soft cloths
  • Paper towels
  • Microfiber 2-sided bath mitt
  • Ammonia-based glass cleaner
  • Used dryer sheets
  • Shaving cream
  • Shampoo or bubble bath
  • Rain-X (TM) or other rain-repelling windshield washer fluid
Your fog-free shower mirror is a great convenience but it can still develop a soap scum layer after a few weeks. Several methods to clean it and to protect its finish will be discussed below. The most important thing to remember is to clean your shower mirror so that the fog-free coating will be protected. Otherwise, you will need to get another fog-free mirror. Follow these suggestions and tips below to safely clean soap scum off your shower mirror.
Step 1: Remove the Shower Mirror from the Shower
Dampen the shower mirror surface and rub briskly with paper towels to remove the topmost layer of soap scum. Apply a cream-based shaving cream, not the gel type, all over the mirror surface. Rub with paper towels or a soft cloth until all the shaving cream has disappeared to lift off stuck-on soap scum.
Step 2: Apply Shampoo or Bubble Bath to a Damp Mirror
Squirt one drop of shampoo onto the mirror and work it into a lather with paper towels or a washcloth. Rub steadily until the soap scum has been lifted. Bubble bath with soap scum inhibitors, applied like shampoo, also works well on shower mirrors.
Step 3: Rub the Mirror Surface with a Used Dryer Sheet
The fabric softener in most dryer sheets can remove sticky film from glass and mirrors. Make sure the mirror surface is perfectly dry before using a dryer sheet on it. Rub the dryer sheet all over the mirror, and you will be able to see the scum darkening the dryer sheet fibers.
Step 4: Use a Bath Mitt to Scrub the Mirror
Rubbing the mirror with the scrubber side of a 2-sided microfiber bath mitt will enhance the cleaning power of any of the cleaners mentioned above. The soft microfiber will not scratch or damage the mirror's fog-free finish.
With a soft cloth, apply a light coat of any of the rain-repellent windshield washer fluids, such as Rain-X (TM) to the mirror. Soap scum will not stick to your mirror, and water beads will shrink in size, enabling you to see in the mirror clearly even when it is wet.
Step 5: Cleaners to Avoid Using on Your Fog-free Shower Mirror
Do not use vinegar on your shower mirror, or any of the specialized bathroom cleaners such as Scrub Free (TM), BioClean (TM) or Scrubbing Bubbles (TM) meant to remove soap scum from tile and stainless steel. These cleaners will remove the fog-free coating from your mirror. Do not use any abrasive cleaners on your fog-free mirror, as these will both scratch the mirror surface and lift off the fog-free coating.
 forum activity
