Login Error
Close
How to Clean Vomit Off Of Any Fabric
by DoItYourself Staff
When you are called upon to clean vomit it is a rather unpleasant job. However, if you have had sick children you know that this job will be soon coming. While it is an unpleasant job it can be easily done with a few simple steps.
Clean up Solids with Paper Towels
Without applying too much pressure, clean up the solid parts of the vomit with paper towels. If you press too hard, it will smear into the fibers of the fabric, making it harder to clean up.
Remove Any Fabrics That You Can
If the vomit is on an item such as a rug, bed sheet, pillow case, cushion covering or some other item that you can remove, wash it in hot water. Hand washing is recommended. Apply a stain remover to the area first and let it soak in warm water and laundry detergent for 30 minutes to one hour before washing.
Scrub Clean
Use a soft bristled brush or sponge to clean the vomit from the area.
Use Stain Remover on Carpet
If the vomit is on a carpet, spray carpet stain remover onto the area and let it dissolve some of the vomit from the fibers. Use a steam cleaner on the area until the vomit is removed.
 forum activity
