Login Error
Close
How to Clean Wood Kitchen Countertops
by DoItYourself Staff
what you'll need
  • Water
  • Soap
  • Rag
  • Vinegar
  • Spray bottle
Wood kitchen countertops can provide your kitchen with a beautiful focal point and a great deal of functionality at the same time. When it comes to cleaning these countertops, there are certain things that you will need to avoid and a few procedures to keep in mind. Follow the simple steps below to effectively clean your wood kitchen countertops.
Step 1 - Wipe Down the Counter
Anytime that you have food or liquid on the counter, you need to wipe it off as soon as possible. If the liquid is allowed to sit on the countertop for an extended period of time, it can seep into the wood and stain the counter. You also need to remove any excess food that is on the counter before you try to clean.
Step 2 - Clean the Counter
When you clean the counter, you want to make sure not to use any abrasive chemicals such as bleach or ammonia. Instead, start out with a mixture of soap and water and wipe down with a rag. If this does not work, you can instead create a mixture of vinegar and water. Put the mixture in a spray bottle, spray the counter, and then wipe off with the rag.
 forum activity
