How to Clean Your Cellular Shades
Cellular shades are a great way to decorate any room, and they can provide privacy as well as insulation. They can require more cleaning and care than other kinds of shades, but with the right kind of care and attention, they can look clean and new for many years. When cleaning cellular shades, it is important not to damage the fabric by creasing or over-rubbing. If the dirt proves too difficult to remove by yourself, then you should call in a professional cleaner: you may wish to monitor their cleaning to ensure that excessive soap or other cleaning agents are not used. Be certain that the cleaner or your insurance company will pay for the cellular shades to be replaced if any damage should occur.
Cleaning Cellular Shades
The best way to clean off dust and accumulated dirt is with either a feather duster or a vacuum cleaner. Briskly rub any particularly dirty areas with the cleaner. When vacuuming, remember to put the shade into a closed position, and then gently vacuum the material, using the brush extension if you can. Clean both sides until the dust and dirt has been removed. Regular vacuuming helps to prevent stains and dust-bunnies from building up and can prolong the life of your shades.
Some cellular shades can be immersed in water to clean them. Using only a little detergent and warm water, then place in the water, being sure to avoid the head rail. Swishing water through the shades will help to wash away dust and long-standing dirt. After immersing in water, hang the shades up to dry. Avoid using a hair-dryer, and ensure that the window is shut until the material is totally dry.
To clean cellular shades that have become dirty through accidents or by being splashed, use a spot cleaner or vigorously rub soap and water over the surface. If it is only a little spotting, then wipe away dirt with a warm damp cloth. Do not use strong liquid detergent, spot removers that are designed for carpets, or bleach, as any of these could remove the color dye and leave mottled patterns on the fabric. Cellular shades are also fixed together using glues that can become unstuck through the use of harsh chemicals, so only use cleaners if the dirt is only on the shade's cloth, and not on the glued seam.
Cleaning Homeycomb Shades
Regularly clean honeycomb cellular shades using a vacuum and the brush extension, which can sweep away dust that has settled into the fabric. Without regular cleaning, honeycomb shades can develop an unattractive yellowy tint, making them look old long before their time.
If the vacuum is having trouble removing all the dirt, then you can try using a blow-dryer or air compression machine to blow warm (not hot) air through the honeycomb.
