How to Connect a Karaoke Machine to Your Computer
what you'll need
- Fully equipped computer
- Karaoke machine
A karaoke machine is a great entertainment tool and can be fun when connected to the computer. The karaoke machine when hooked to the computer facilitates to record the singing attempts.
Step 1 – Checking and Connecting
Locate the plug point which connects the monitor and the amplifier, at the back of the computer. Now connect the audio and the video lines of the karaoke machine to the marked slots at the back of the computer.
Step 2 – Adapter
Some computers may not have slots for the plugs of the karaoke machine. In this case, buy an adapter to plug the audio and the video lines. Follow the instruction manual to figure out which line goes where.
Step 3 – Trial
Turn the karaoke machine on and run it though a trial. If the karaoke machine does not function correctly, then switch off the machine and disconnect the amplifier. Reboot the computer and reconnect the karaoke machine. This should fix the problem.
Step 4 – Tip
The hard disk is a good place to store the songs that will be played on the karaoke machine. Burn the singer's attempts using the CD drive.
