How to Convert a Shower into a Dry Sauna
what you'll need
- Shower that is a good size
- Pencil
- Paper
- Measuring tape
- Drill
- Drill bit
- 120 volt heater
- 1/2 plywood for wall sheeting
- Caulk
- Caulk gun
- Wood finish
- Paint brush
Building a dry sauna is actually not as difficult as it may sound when you have the right tools. Here are a few easy steps to follow to get you through the process smoothly.
Step 1 - Map It Out
The first thing that you are going to want to do for this project is map everything out because you will be in a tight space and laying it out to begin with can avoid any big problems down the line. You will start with adding wood to the inside of your shower so you will want to account for about a half an inch thickness on every side which will in turn make the area a little bit smaller than it was originally. Also you will want to know where you will be setting up the heater as well as where you will be connecting the wires and drilling through.
Step 2 - Run Power Lines
Many times you will want to have someone else come in and do this as it can be tricky to do and you will be dealing with water near a power line. If you are up to the job yourself make sure that you begin by shutting off the water and power to that area before doing anything else at all. Then you can decide where the heater will be and drill a hole through the wall of the shower to fit the wiring through. This is going to run probably from the wall of the sauna down and then through a hole in the floor or wall near it to lead down to the outlet or power source.
Step 3 - Install Wood
You will need to use a drill as well as sheets of 1/2 inch plywood to sheet the inside of your shower. Make sure when you are doing this that you are keeping the hole in mind so as not to cover it up. The walls, ceiling and floor all need to be done with the sheeting. If you choose to stain them then you can paint the stain on with a paint brush then allow it to dry before putting on another coat. Then let it dry completely before moving on.Once the plywood is finished you can install with a drill the cedar boards on the walls of the sauna to get a more relaxed and professional feeling and look to your sauna.
Step 4 - Seal Everything
Go through and check for any opening or cracks to make sure that everything is sealed off or the heater will not work properly. If you find an opening then just use the caulk gun to apply caulk to the area and let sit.
Step 5 - Install Heater
Now you can install a heater in the corner of the shower by hooking it up to the wiring that you installed earlier.
Once you are finished you can set your heater to about 185 degrees and enjoy.
