Login Error
Close
How to Cover Popcorn Ceilings
by DoItYourself Staff
what you'll need
  • Protective plastic drop cloth
  • Polystyrene ceiling tiles
  • Utility knife
  • Putty knife
  • Ceramic wall tile adhesive
  • Chalk line
Covering your popcorn ceilings is probably a better economic decision than removing it. Scraping it smooth and then coloring can require more effort than it‘s worth. The scraping method involves a lot of substance removal and dust, making it a hazardous attempt to beautify your ceiling. An alternative method is to directly install ceiling tiles, glued straight over the existing popcorn ceiling. The entire project can be inexpensive and completed quickly.
What Is a Popcorn Ceiling?
A popcorn ceiling refers to a popular spray-on paint treatment used extensively in home construction during the 1960s and 70s. It consisted of a bright white, lumpy texture that contained bits of gold or silver glitter, that could be inexpensively applied with commercial spray paint equipment. It became the choice for bedroom and hallway ceiling treatment, due to its easy application. Unfortunately, homeowners and builders alike soon learned that popcorn ceilings are extremely hard to clean or paint over.
Step 1 – Preparation
There is practically no preparation, except making sure the ceiling is free of cobwebs, with no incidental foreign matter protruding from it. It is a good idea, however, to place a protective plastic drop cloth over the floor. Make sure when using more than one to overlap the cloths at least four inches to ensure protection. Also, rolling the cloths together will help with easy cleanup once you have completed installation. Measure a tile and then apply a chalk line that distance to either side of a center point in the ceiling, marking the first row of tiles.
Step 2 – Using Glue
Here’s where the glue becomes your new best friend. Depending on the depth of the popcorn effect, use enough glue for really deep effects, by applying it with a putty knife to the back of the polystyrene ceiling tile.
Step 3 – Start Tiling
Although you should start from the center of an average sized or bigger room, you can start in the corner when working in a smaller room.
Step 4 – Optional Molding
If you want a really great look, install expanded polystyrene crown molding to add a finishing touch.
Tips to Consider
  • Using ceramic tile adhesive for applying polystyrene ceiling tiles makes the project easier to complete, and very easy to clean up after installation.
  • Make sure all installers keep their hands clean or use protective latex gloves.
  • Use a silicone caulk that can be painted to fill in any gaps between tiles.
  • If you want to paint the tiles, use latex or acrylic based paint. It is a good idea to paint the tiles before installation.
 forum activity
