How to Cut Formica Sheets
what you'll need
- Formica blades
- Utility knife
- Masking tape
- Straight edge
Many people use Formica to redecorate their kitchens. Whether you want to cover your cupboards or use a sheet of Formica in some other way, you will first need to learn how to cut it.
Step 1 - Prepare the Formica
Prepare the Formica so it's ready to be cut. Roll out the sheet until it is flat. You can keep it in place with weights on the corners of the sheet. (Books or anything else of a similar weight will work.)
Step 2 - Take and Mark Measurements
Now you need to measure the area of cabinet or worktop that you need to cover with the Formica. Make sure your measurements are accurate so you don't waste the Formica. Measure twice and only cut once!
Once you have measured the area, mark those measurements on the back of the Formica with a pencil. Once again, double-check your work. You want the Formica sheet to fit accurately.
Step 3 - Mask the Formica
Now you need to protect the surface of the Formica with using masking tape. Put the tape over the pencil line you've just drawn, and the line should show through. You then need to draw this line again so you can see it clearly. Use a straight edge to make drawing lines much easier and more accurate.
You may also like to place something under the face of the Formica sheet so that it is fully protected and won't be damaged by anything else. Any grit or dirt on the cutting surface could scratch the surface of the Formica.
Step 4 - Cut the Sheet
Use your straight edge and utility knife to cut along the line as accurately as possible. Use the utility knife first, as it will provide a good, clean cut. Then grip the wasted area of Formica and lift it up slightly. The Formica should break off and leave a good cut.
Be very careful not to get your fingers in the way of the blade. Otherwise you could end up with a nasty injury.
If you need to clean up the cuts, you can also use the Formica blades to do so.
