How to Cut Plastic Ceiling Paneling
what you'll need
- Saw
- Pencil
- Measuring tape
- Pencil
Many people utilize plastic ceiling paneling in their homes. When preparing for this task, you have to be sure to make the cuts around any devices installed the ceiling. You can save money by doing the job on your own.
Step 1 - Measuring
Pick up your measuring tape and measure the ceiling inside your home. Make sure that the measurements are correct, and take enough time to do the job right.
Step 2 - Marking
Take your pencil and place lines on the ceiling panel that willl be cut. It is very important that the ceiling space is also marked with the pencil to ensure proper placing.
Step 3 - Inspection
Place your ceiling panels on a flat surface and look for any scratches, cuts or damages. If there is dirt on the panels you can clean them off with detergent.
Step 4 - Cutting
Place your saw on the marked lines on the panel and cut straight lines. Be sure that the cuts are even with the ceiling space.
Step 5 - Finishing
Place the finished ceiling panel up to the ceiling space to see that it is a perfect fit. Do each of the panels in the same fashion, until the job is completed.
