Login Error
Close
How to Develop a Reliable Deicing System for Frozen Pipes
by DoItYourself Staff
Having an effective deicing system in place will help to avoid having your pipes freeze during the cold winter months. Frozen pipes can easily cause you a significant expense, if they end up bursting. If your pipes freeze, you have to make sure to thaw them as soon as possible. Rather than doing this though, you should try to take measures to avoid having them freeze in the first place. There are a number of ways in which you can do this. Let us discuss such methods in further detail.
Deicing Cables
Deicing cables are a rather effective part of a deicing system. They basically work by using heating wires, controlled by a thermostat, to provide a suitable temperature against the low climatic temperatures. They help to avoid ice dams and possible resultant leaks. They also have the advantage of being relatively easy to install.
Covering and Insulation Techniques and Alternatives
If you have any pipes which are exposed, consider covering them up, or sheltering them in some way. Exposed pipes are bound to freeze. There are a number of ways to cover pipes. One method is to apply electrically powered heat tape over them. This type of tape provides protection to the pipes, and avoids having them freeze. Wrap it around the pipe in a spiral manner, and leave a small gap in between 1 band and the other. Another effective method of protecting pipes is to use fiberglass insulation. This type of insulation is considered the most effective, however if you are going to install it yourself, beware of its irritating components. If you wish to avoid using fiberglass insulation, or if you wish to spend less money, you can use rubber insulation. This is much easier to install, and less costly too. It is worthwhile spending some money in preventative measures, rather than ending up with frozen pipes and costly repairs as a result. If you do not wish to spend money on insulation though, you can always opt to cover pipes with old clothes, towels or blankets. The most important thing is that they are covered up well, so as to create an air pocket and provide an insulation. Tie coverings well with string, to avoid having them get loose, be blown away or fall off.
Water Flowing
One technique you could consider using in case of exposed pipes, is to allow a trickle of water to flow through them. The continuous flow of water will reduce the possibility of having the pipes freeze. Obviously, make sure that only a little water is flowing, as you do not want your water bill to be tremendously high as a result.
Installing a No Freeze Water Faucet
You can also consider installing a no freeze water faucet. These types of faucets are ideal for outdoor use, as they enable water to drain away from the pipe effectively.
Using a Water Heat Rod
You can also purchase a water heat rod. Simply plug it into an electrical socket, and it will maintain a warm temperature for your pipes once the temperatures drop.
 forum activity
