In order to downgrade the voltage on a 6v battery, here are a few steps, tools and materials needed to accomplish this task.
Tools and Materials Needed:
- 6-Volt Battery
- 4-Volt Battery Charger
- Battery Tester
Step 1: Connect the 6-Volt Battery
Set up the 4-volt battery charger in accordance to its instructions. Connect the 6-volt battery to the 4-volt charger. This should downgrade the 6-volt battery to 4-volts by discharging the voltage.
Step 2: Disconnect Battery Charger
After the discharge has been completed, disconnect the 4-volt battery charger from 6-volt battery.
Step 3: Test the 6-Volt Battery
Use a battery tester to determine if the 6-volt battery has been discharged. If not, repeat steps 1 and 2.
Please note that this process could result in damage to the 6-volt battery or the 4-volt charger, if they are not of equivalent quality. Also, this article makes no assurance that following these steps will result in a downgrade in voltage from the 6-volt battery.
Questions of a Do It Yourself nature should be submitted to our
