cancel
Job type :
Zip Code :
community forums
comments
How To Dry Food: Fruits And Veggies
Food dehydration is one of the oldest methods around to dry and preserve food. With the water removed, there is no worry of spoilage through mold or bacteria with the dry food. You can dry food using one of these three easy methods:
Sun Drying
This method takes the longest and it’s the most difficult only because you must rely on having 3 to 4 consecutive sunny days where the temperature is at least 100 degrees.
Oven Drying
If you want to dry food quickly this method works well, but you must be able to hold the temperature steady below 200 degrees Fahrenheit in order to properly dry food. The biggest draw back here is that the food does not have great flavour.
Electric Dehydrating
This is the best method to dehydrate food. It’s energy efficient, and maintains the nutrition as you dry food for storage.
Drying Guide for Fruits and Vegetables
It takes approximately 6 to 16 hours to dry vegetable and 12 to 48 to dry fruit. Wash, slice, and branch each vegetable, except mushrooms and peppers. To dry the vegetable and fruit, lay them out on the tray appropriate for how you are drying.
  • Apples: Peel, core and slice into 1/2 inch to 1/4-inch slices. Dry 5 to 10 hours or until pliable.
  • Bananas: Peel, then cut into 1/4-inch slices. Dry 10 to 20 hours or until almost crisp.
  • Beets: Cook and peel beets. Next cut into 1/4 to 1/2 inch pieces. Dry 2 to 8 hours or until leathery.
  • Blueberries: Dry 10 to 20 hours or until leathery.
  • Broccoli: Cut and dry for 4 to 10 hours.
  • Carrots: Peel and slice carrots. Dry 5 to 10 hours or until brittle.
  • Cauliflower: Cut and dry 4 to 10 hours.
  • Cherries: Cut in half, then dry 20 to 30 hours or until leathery.
  • Green Beans: Break beans into pieces1/2 to 1 inch then blanch. Dry 5 to 10 hours or until brittle.
  • Onions: Slice onions 1/4 to 1/2-inches thick. Dry 5 to 8 hours or until crisp.
  • Peaches: Peel, then cut into quarters. Dry 8 to 24 0 hours or until pliable.
  • Peas: Dry 5 to 15 hours or until brittle.
  • Peppers: Remove the seeds then chop. Dry 4 to 10 hours or until leathery.
  • Strawberries: Wash and cut into 1/4-inch thick slices. Dry 5 to 18 or until almost crisp.
  • Tomatoes: Dip in boiling water to loosen skins, then peel and into quarters. Dry 5 to 10 hours or until crisp.
The Right Temperature
The food should be dried between 120 and 140 degrees Fahrenheit. You can tell when the food is dry when it feels leathery to the touch. When you tear a piece in half, there should be no moisture beads along that tear. In addition, the vegetables will be crisp.
Storing
Store dry food in a container where no moisture is able to enter. Freezer bags work well for storing the dried goods. Also, store them in a dark, cool place for future use.
member comments
Related Articles
How to Dry Sage Leaves
Sage leaves can be dried and stored for as long as one year, after which... read more
Jerky
How to make your own jerky... read more
How to Keep a Mini Fridge Clean and Mold-Free
Keeping a mini fridge clean is an easy task as long as you know what... read more
articles we like
Why is Christmas celebrated on December 25?
This article has creative christmas decorations you can make using Christmas tree balls... read more
Electric Socks
Electric socks have come a long way since the 1950’s when they were first invented... read more
An All Natural Energy Kick Start for Your Busy LifeAn All Natural Energy Kick Start for Your Busy Life
Energy bars without the fat and sugar, but wonderful, fruity taste... read more
sponsored articles of the day
diy centers
