Login Error
Close
How To Eliminate Fruit Flies From Vermicompost
by DoItYourself Staff
Vermicompost is one of the most effective organic fertilizers. A single teaspoon of vermicompost is sufficient to feed a potted plant for nearly 2 months. It is produced from controlled decomposition of organic matter. The preparation of Vermicompost from a compost pile is called Vermicomposting. Here, worms begin to digest the decaying organic matter and excrete a unique, nutrient-rich material called Worm Casting. Vermicompost tea or compost tea prepared form vermicompost is regarded as the single, most comprehensive source of plant nutrients. It is also called worm tea.
Unlike regular compost piles, the vermicomposter or the bin containing the pile can be placed indoors. This makes vermicompost a readily-available, easy-to-produce natural fertilizer for apartment dwellers also. The container in which the pile for preparing vermicompost is placed is called a worm bin. Maintaining the worm bin is not difficult but it does attract one universal problem: Fruit flies. Fruit flies are comprised of many species of small, fast-multiplying flies under the genus Drosophila. They are also called vinegar flies or pomace flies. A common fruit fly, found in most gardens, is the Drosophila melanogaster. Eliminating fruit flies requires a bit of patience along with using the following tips:
1. Take Care of Peels
You should not overload your worm bin with vegetable and fruit peels. These are the favorite feeding items of a fruit fly. Fruit fly eggs are commonly found on the outer surface of fruit peels.
  • Scrubbing
If your household produces an excess of vegetable peels, then scrub them with water before dumping them in the composting pile. Scrubbing ensures that the flies aren't attracted to the peels. Secondly, peels within the kitchen itself are sometimes scattered with microscopic Fruit fly eggs. Therefore, scrubbing is also a method of ensuring that you are not introducing fruit fly larvae in the worm bin.
  • Microwaving
A quicker method is putting the collected organic matter in the microwave and letting it cook for a minute. This ensures that the excess moisture and leaking juices from the peels are dried. It also kills any fruit fly eggs that may have been laid on the peels.
  • Manipulating the Pile
To prevent fruit flies from multiplying in the worm bin, bury the peels deep inside the composting pile. This ensures that the newly-laid eggs are suffocated due to the burden of overlying organic matter.
2. Use Fruit Fly Traps
These are simple, cheap and effective tools for getting rid of fruit flies. You could use the soda bottle trap.
Making Soda Bottle Trap
  • Empty and dry a two-liter plastic soda bottle.
  • Cut along the upper end of the soda bottle, i.e. along the part that is labeled, using a blade.
  • Put sweet, fruit fluids like orange juice or vinegar inside the bottle.
  • Place the bottle inside the composting pile.
  • The trap should look like a cone, i.e. with the capped end on the outside and the holed-out part towards the inside.
  • Seal the bottle’s capped area with duct tape.
  • Fruit flies start entering the bottle due to the fruity fluids.
  • When many Fruit flies have gathered, quickly pull-out the bottle. Shove the bottle inside a plastic bag and dump it.
    3.  Check Vermicomposting Pile Ingredients
    You should never add the following ingredients to your Vermicomposting pile:
    • Meat products: beef, chicken, poultry, fish and pork
    • Grease/fats: butter, margarine, mayonnaise and salad dressings
    • Dairy products: cheese, milk and yogurt
    They don’t support the multiplication of worms that is needed for Vermicomposting. Instead, they lead to the multiplication of unwanted microorganisms that makes the decomposing pile more favorable for fruit flies.
     forum activity
