Login Error
Close
How to Find Leaks in Damp Basement Walls
by DoItYourself Staff
Damp basement walls are a result of the water seeping in the walls. This water damages the structure of the basement walls as well as the whole building. Damp basements cause various respiratory problems due to mold growth. It is important to repair the damp basements by detecting the leaks in the basement walls. Follow the directions below to find the leaks in your damp basement walls.
Step 1 - Detecting Mold
Examine the walls of your basement to detect mold. If you find mold or mildew growing on any part of the wall, there is a leak in that part from where excess water is seeping in and is feeding the molds. Mold is easy to find as it is colored, and black mold is the most dangerous of them all. If your walls have fungus grown on them, it also shows presence of a leak.
Step 2 - Smelling Air in the Basement
Another way to find out if your basement walls are leaking is by the smell in the basement. If there is a musty smell or odor in the air and the walls smell stronger, you probably have a leak. The odors produced come from the bacteria, fungus, mildew and mold grown on the damp walls. As the water seeping in from the walls rots things, you can also smell the odor of decay.
Step 3 - Finding Efflorescence & Examining the Wall Color
Another indicator of leaks in a damp basement wall is the efflorescence. Examine your walls to find efflorescence, which is identified as a white and chalky residue. It is produced when there is a presence of heavy moisture due to water penetration in the walls. If you find it on your damp walls, there is certainly a leakage in the walls. Another way for finding leaks in the basement walls is looking for discoloration of the walls. When there is a leakage in the walls, the seeping in water leaves stains on the walls and discolors it. These stains are usually big and brown in color, spreading across your basement walls.
Step 4 - Inspecting Metal and Wood Items
If your damp walls are leaking, they are likely to damage the metal fixtures and wood items in the basement by producing excess moisture in the air. Rusting metal items such as nails, rotting wood and peeling paint are all the indicators that your basement walls are suffering from some kind of leakage.
Step 5 - Seepage or Condensation
Once you have detected that your damp walls have possible leakages, you must confirm if the water on the walls is because of condensation or seepage. Tape a small piece of aluminum foil to your basement wall and leave it on for a few days. When you remove it, examine the surface of the foil. If you find moisture on the surface that touched the wall, there is a leak in the wall. However, if the outside surface of the foil has moisture, then you are dealing with condensation.
 forum activity
