How to Finish a Wooden Picnic Table
what you'll need
- Paint brushes
- Sanding sealant
- Sandpaper
- Wood stain
A wooden picnic table right at your garden is a fun dining venue on weekends. However, wooden picnic tables are exposed to outdoor elements most of the year and needs extra protection. One way to protect your wooden picnic table from outdoor elements is to apply finishing. Here are the materials that you will need along with the instructions on how to finish a wooden picnic table.
Step 1 - Sandpaper
Smooth the surface of the picnic table using fine sandpaper. Start at the table top and sand in a circular motion until your get a relatively smooth and even surface.
Step 2 - Apply Sanding Sealant
With a paint brush, apply a sanding sealant on the surface of your picnic table and dry for 30 minutes. Sand the picnic table again using the procedure in Step 1.
Step 3 - Apply Wood Stain
After sanding, apply a coating of wood stain on the picnic table using a fresh paint brush. For a lighter wood stain apply only 1 or 2 coats of wood stain. For a darker wood stain apply additional coating until you are satisfied with the hue of the stain. Make sure to allow enough drying time between each coating of wood stain.
Step 4 - Remove Excess Stain
Check your picnic table for excess stain and remove any by sanding. Excess stain often accumulates at the end pieces and corners of your picnic table.
Step 5 - Finish
Apply polyurethane finish on your picnic table using another fresh paint brush. Apply 2 or more coatings to protect your picnic table from outdoor elements such as rain or direct exposure to sunlight.
