Login Error
Close
How to Finish Quarter Round Molding
by DoItYourself Staff
what you'll need
  • Putty knife
  • Nails
  • Tool set
  • Quarter round molding ( this are mainly found in two varieties wood and plastic)
  • Measuring tape
  • Chop miter saw
  • Pencil
Quarter round molding is a unique concept that not only makes your floor attractive but also protects it from getting dirty. After all, who does not love attractive wood floors? These wooden floors not only look attractive but also add beauty to the house. Just following a few simple guidelines, you can create a Spartan look for your room all by yourself.
Step 1: Coloring the Quarter Round Mold
Get hold of a quarter round mold and colour them as per your requirement. Ensure that you give adequate time to the quarter round mold to dry up otherwise you will end up smudging the paint. Ideally,first you should apply a colour coat to ensure the colour grips the mold well. Once the coat dries , apply the desired colour.
Step 2: Select the Right Sized Mold
All quarter round molds that are available in the market are around ¾ inch thick. This is their actual thickness. Hence, it is important to choose the mold size with extra care.
Step 3: Cutting the Mold
Just like in case of installing a foot mold, even for a quarter round mold one needs to make cuts at an angle of 45 degrees. So, in case you need to mold all the four walls in your room, you need to make all cuts at the same angle of 45 degrees.
Step 4: Installing the Quarter Round Mold
Installing a quarter round mold is simple until you come to a door. On reaching a door, keep a little extra and then cut the remaining extra part of the mold at an angle of 90 degrees. Ensure that all edges between the wall and the door is deftly covered with butt joints.
Step 5: Joining the Strips
In case of a joint or corner ensure that the two strips of quarter round mold used to cover that area are cut at an angle of 45 degrees but in an opposite direction. This is to ensure that the molds can slide over each other and give a seamless look. Moreover, these slides will ensure that the quarter round mold is firmly at place
Step 6: Nail the Mold to the Floorboard
One the quarter round mold is placed and cut, nail them on to the floorboard using nails. Ensure that you hit the nails in an angle to ensure that they penetrate into the floor board and hold the quarter round mold in place.
Step 7: Using the Putty Knife
Once the nails are placed cover them up using a putty knife to get an even look. This technique  can also be used to smoothen out the rough edges if any.
Expert Tip:
Remember a quarter round mold is not a replacement for the baseboard. It is supposed to accentuate the look of a baseboard. A baseboard is an integral part of the structure , as it gives support to the frame.
 forum activity
