Login Error
Close
How to Fit and Install a Concealed Hinge
by DoItYourself Staff
what you'll need
  • Concealed hinges
  • Mounting screws
  • Screw driver
  • Tape measure
  • Pencil
Installing a concealed hinge can add beauty and grace to your kitchen cabinets. A Concealed hinge is also know as a European hinge.
Step 1 - Measure Your Cabinet Door
The height of your cabinet doors as well as there placement will determine the number of concealed hinges that will be installed in each door. For instance a 12 inch high cabinet door would only require 2 concealed hinges to be installed on each door where as a 42 inch cabinet door would require 3 concealed hinges.
Step 2 - Drill Your Mounting Holes
For a cabinet door that only requires 2 concealed hinges you will drill your mounting holes 3 inches down from the top and 3 inches up from the bottom of your door. To drill your holes appropriately for a concealed hinge you will need to use a "Forstner" bit that will not punch a hole all the way through your cabinet door. Your hole will need to be 1 1/4 inch in diameter and will need to leave a 1/4 inch reveal in the outer edge of your cabinet door.
Step 3 - Install Your Hinges
Place your concealed hinge into the mounting hole that you drilled and attach it with the mounting screws that were provided with your hinge.
 forum activity
