Login Error
Close
How to Fix a Dishwasher that will not Drain
by DoItYourself Staff
Having a dishwasher that does not drain properly can put a strain on the average user.  Now-a-days, a dishwasher is a common appliance in many homes around the country. Many families rely on their dishwasher to take one chore off their hands. Understanding how to fix a dishwasher that is not draining properly can provide you with additional time to spend with your family which is why you have one in the first place.
How to Fix a Dishwasher that is not Draining
  • Check the power supply - If the fuse is blew; the dishwasher will not operate as well as drain.
  • Make sure the dishwasher has finish a full cycle - Stopping the dishwasher mid cycle can cause it not to drain.
  • Make sure the door is securely shut - If the door is coming off its hinges or not properly closing then it can cause problems with the draining process.
  • Remove food trapped in the drain - Check the bottom of the dishwasher. If there is any food that is stuck around the drain it could be obstructing the water from draining.
  • Check the hoses - Make sure the hoses are properly attached to the back of the dishwasher. If the hoses have become loose it can cause the dishwasher to stop draining all together.
 forum activity
