cancel
Job type :
Zip Code :
community forums
comments
How to Fix a Squeaky New Door
Everyone has experienced the annoyance of an old door that squeaks, but when a new doordoes it, the results can be even more frustrating. However, there are simple ways you can stop a new door from squeaking, and the tips below will cover some ways to keep your door swinging quietly and effeciently.
Materials Required:
  • Level
  • Screwdriver
  • Screws
  • Lubricant
Temporary Fix
When most doors squeak, the noise is often the result of the parts of the hinges rubbing against each other. As a result, many homeowners have found that adding lubricant on the hinge can stop a door from squeaking. However, you should keep in mind that if you decide to use this solution you are only applying a temporary fix to what is generally a structural problem with your door. As such, you should apply lubricant if you need an immediate quick fix, but keep in mind a greater solution may be necessary. For this temporary solution, use a proper type of household lubricant, such as WD-40, for best results.
Go to the Root of the Problem
The next option is to attack the true root of the problem directly. As mentioned before, most squeaking is a result of grating hinges. With that in mind, you should try to tighten any loose hinges on the door as a way to attack the problem. More often than not, the top hinge will be the culprit since most of the weight of the door is placed in this area.
Check the Alignment
One other way to make sure your new door stops squeaking is to check the alignment. Sometimes, doors are installed imperfectly, and the door may droop at a slight angle. This is easily verifiable by either checking by sight to see if your door aligns with top of its frame all the way through, or by placing a level parallel to your door. If the door was not properly aligned, you can usually fix it by loosening the hinges, re-adjusting the door, and then tightening the hinges once again with the door held in a more straight alignment.
To conclude, although a squeaking door can be a nuisance, there are several ways to fix this problem without too much hassle or effort.
member comments
Related Articles
Repairing and Replacing Mobile Home DoorsRepairing and Replacing Mobile Home Doors
Tips on repairing and replacing mobile home doors... read more
How to Frame a Door
Step by step instructions for building a door frame, hanging the door, and adding a... read more
How to Replace a Door
How to Replace a Door... read more
articles we like
Ribbon
In construction terms a ribbon refers to a board or lengths of board which are... read more
AdhesivesAdhesives
This tool section introduces you to adhesives... read more
What Do Employers Want? Smooth Talkers, Good Readers
The following article discusses how the ability to communicate effectively can land you a secure,... read more
sponsored articles of the day
diy centers
