How to Fix a Washing Machine that Won't Fill with Water
what you'll need
- Screwdrivers
- Wrenches
- Volt-ohm meter
When your washing machine won’t fill with water, you’re going to need to repair washing machine problems immediately. Doing it yourself is a much cheaper proposition than calling in a plumber. In most instances, it’s a job you can manage yourself with just some basic tools and a little time. Generally, the problem will be fairly simple.
Step 1 - Hoses
Start by pulling out the washing machine so you can see the hoses. First check whether the faucets are on, and whether they are allowing water to enter. If not, this could be one reason why the washing machine spins but won't fill with water. It could be that the hose is kinked, which would prevent water passing through. This means the washing machine won’t fill. If this is the case, simply straighten the hoses. Try the washing machine again to check that it fills properly.
Step 2 - Water Level Switch
The reason the washing machine won’t fill could lie with the water level switch. To test this, you’ll need to open the washing machine up and locate the control panel. The water level switch is easy to spot since it has a clear tube running to it. You’ll need to test it with your volt-ohm meter. Have it set on RX1 and check all three terminals by trying all the possible pairings with the probe. One pair should give you a zero reading and on all the others, the reading should be infinity. If not, you’ll need to replace the water level switch.
Step 3 - Filters
One common reason for the failure of a washing machine to fill is heavy clogging in the filters. First, unplug the washing machine then disconnect the hoses from the back of the unit. You’ll be able to see the filters on the back of the washing machine sitting in the water inlet valve. Clean these out, reconnect the hoses and try again.
Step 4 - Water Inlet Valve
If the filters are clean, you’ll need to check the water inlet valve. The chances are that you’ll need to replace the valve to repair the washing machine. You should also check the water volume selector switch to ensure it’s set properly and that the buttons on the control panel are fully depressed. If these are not correctly set, a simple adjustment should repair your washing machine problems.
Step 5 - Pressure Chamber
If the pressure chamber of your washing machine is blocked, air can become trapped in the pressure tubing. This causes the pressure switch to remain on. You can diagnose this problem because the machine will wash and spin even though there is no water present. You’ll have to clear the tube to repair washing your machine problems or replace the pressure chamber.
Step 6 - Very Slow Flow
If the water only flows and fills very slowly and both the hoses and the filters are fine, the problem will be in your house plumbing.
