Login Error
Close
How to Fix Common Wireless USB Hub Problems
by DoItYourself Staff
A wireless USB hub provides a connection routing hub for your computer. When the hub is not working properly, follow the steps below to address the problems with the malfunctioning components.
Step 1: Fixing a Malfunctioning USB Hub
Hardware devices run with a device driver for the computer to operate. A common problem happens when you plug in a USB device and the computer asks for the device driver. This indicates that the device driver is missing, improperly installed or not working correctly. A yellow explanation mark in the USB root hub found in the device manager is your sign. Since versions of Microsoft Windows (2000 and up) automatically detect missing device drivers and searches for them, if this is not the case with your wireless USB hub, simply go to the device manufacturer online and manually download the latest driver.
Step 2: Checking If the USB is Incorrectly Configured
The malfunctioning device connected to a wireless will cause the computer to freeze. Switching the computer or the hub off and turning it back on will reset the bus and could solve the problem.
If this problem persists it may indicate that the USB hub is not properly configured. Uninstall the USB hub, obtain the software used in the initial set-up and configuration and reinstall. Restart the wireless USB hub and see if this corrects the problem with the previously incorrectly installed wireless USB hub.
Step 3: Updating Outdated Firmware or BIOS
Firmware that is outdated can cause various problems for your system. 1 common problem with firmware that is malfunctioning or incorrectly configured is when the wireless USB hub is unplugged and plugged in again and a device is loaded, the device appears and loads again as anoher version of that device. USB devices need firmware which is essential to its operation. This problem indicates outdated firmware or a BIOS system that needs to be updated immediately in order for the wireless USB hub to work.
Step 4: Addressing an Incorrectly Configured Root Hub
A USB root hub in the device manager that appears with the yellow exclamation mark, indicates an IRQ conflict between the device and the computer. Resolved his problem by disabling any USB devices that are not being used from the device manager. This will make IRQs available for the wireless USB hub.
Step 5: Checking for Mismatched Cabling
The cabling used for USB hubs come in low and high speed. Problems with the wireless USB hub not properly working can indicate that the wrong speed cable is being used. Fix this problem by checking the connection speed of the wireless USB hub and making sure that the correct speed cable is in place.
Step 6: Addressing a Disabled USB Controller
The USB controller or the root hub for your wireless USB hub may be disabled in the Device Manager. You can enable the hub by accessing the device manager. Search for the Universal serial bus controller and at the link containing the red X for the USB hub enable the device.
 forum activity
