Login Error
Close
How To Fix Sliding Closet Doors
by DoItYourself Staff
Sliding closet doors make getting into your closet extremely easy. However, daily use presents opportunities for sliding closet doors to malfunction, but most repairs are easy.
If the Door Skips Off the Track
A dirty, obstructed or damaged track can cause a sliding closet door to jump the track. Vacuum debris out of the track, and then wipe the track with a slightly damp rag. Use a mild cleaner if grime remains. Keep the tracks clean by vacuuming periodically with a crevice attachment.
If a room was painted just before the door started to jump the track, inspect the track for stray paint drips that can send the door’s roller off the track. In floor-mounted tracks, screws coming loose may present an obstruction, which you can fix by tightening the screws.
Floor-mounted sliding door tracks are particularly prone to bending. Minor dents in the track can often be pounded straight. Cut a piece of scrap wood to fit snugly in the track and extend beyond the damaged section. Use the wood as a guide and cushion to hammer the track straight. If you notice that your overhead track has minor damage, you can usually bend it into place with pliers. Severe damage calls for replacing the door hardware. Sliding door hardware is sold as a kit with the rollers, track, and guides all in one. To ensure the tracks and rollers are compatible, replace all of the door hardware when you replace one component.
If the Door Sticks
Forcing a sliding closet door that sticks may damage the tracks or rollers if forced. As soon as you notice a sticking door, try to locate the source of the problem to avoid causing more problems.
The easiest fix for a sticking closet door is to tighten the overhead track. If the track wiggles when you nudge it, check the screws in the overhead track and tighten as necessary. Additionally, a sliding closet door may stick if the rollers have worn or developed a flat spot from use. High-quality door hardware will last about 20 years. Replace worn roller wheels, paying attention to the offset from the mounting bracket to the wheel center. Common offsets available are 1/8, 1/4, 7/16 and 1/2 inch.
If the flooring in the room was recently replaced, a sticking closet door may be rubbing against the new, taller carpet or tile. If a taller floor is the problem, you may be able to adjust the height of the door using the screws or knobs on the back of the door that control the roller height so the door will hang plumb.
If you can’t stop chafing with a hardware adjustment, you may need to shorten the closet door slightly. Remove the closet door and carefully plane or file a small amount off the bottom of the door. Use caution and only plane as much as is necessary to free up the door movement, since planing off hollow core doors weakens the door.
If the Door Won’t Close Properly
An improperly closing sliding closet door is usually the result of a misaligned guide on the floor. If the floor guide has shifted, remove and replace the guide so that the door slides into it properly.
 forum activity
