Login Error
Close
How to Fix Squeaky Shower Doors
by DoItYourself Staff
what you'll need
  • Screwdriver
  • Toothbrush
  • Liquid soap
  • Water
  • Soft cloth
  • Water displacing spray
  • Lubricant
  • Paper towels
A squeaky noise is a common problem on shower doors. This is often caused by dirt or rust on the door hinges. The door fails to latch properly when it is closed. This allows water to escape from the shower enclosure onto the floor. A slippery floor can easily cause you to fall and sustain serious injuries. The good news is that it doesn’t take much to fix that squeak, as outlined in the steps below.
Step 1 – Inspect the Hinges
Check the hinges along the shower frame with your fingers to confirm if they’re firmly secured. You may find that a couple of screws have become loose. Tighten loose screws with a screwdriver. Do not tighten too much as it could strip the screw threads and damage the door hinges.
Step 2 – Test the Door
Slowly open and shut the door. Listen keenly for a squeaky sound. It usually emanates from the pivot hinge above the door. As the door is opened and closed, the weight exerts some strain on the upper hinge.
Step 3 – Check the Door Frame
Use your fingers to inspect along the door frame for obstructions. With time, dirt, grit and other fine debris tend to become lodged between the frame and hinges. Use an old toothbrush to gently clear whatever dirt you may spot. Work patiently until you’ve cleaned all round the frame. Clean the hinges with some liquid soap and soft cloth.
Step 4 – Remove Corrosion
Place a thick layer of paper towels beneath the hinges. This will capture liquid that drips from the hinges so that you have less of a mess to clear up. Spray water displacing spray generously onto the hinges, all around. It clears corrosion on the hinges and improves mechanical activity. Open the door to the furthest point and spray on the inside where the hinge attaches to the pin. Close the door. Repeat the open-close activity a few times to allow the water displacing spray to trickle through the hinges.
Step 5 – Apply Lubricant
Open the door wide and position yourself on the inside. Use a soft cloth to generously apply lubricant onto the hinges inside the door. Step aside and close the door. Apply lubricant onto the hinges outside the door. Wipe away excess oil with paper towels. Open and close the door several times. You'll find that the clean and well lubricated hinges now operate without a squeak.
Step 6 – Clean the Hinges
Dilute a small amount of liquid soap with warm water. Apply some of the solution into the hinges. Use a toothbrush to wash the hinges. This helps to clear dirt and fine debris generated during the lubrication process. Rinse the hinges with cool water and wipe dry with a soft cloth. Apply some more lubricant onto the hinges to sustain noiseless movement.
Tip
  • It is best to apply lubricant every few weeks to prevent squeaks on your shower door. Avoid cooking oil as it becomes sticky after several days. This hampers smooth hinge movement.
 forum activity
