Login Error
Close
How to Frame a Basement for Drywall
by DoItYourself Staff
what you'll need
  • 2x4-inch studs
  • 2x4 top plate
  • 2x4 water-resistant bottom plate
  • Combination square
  • 3-inch and 3 1/2 -inchnails
  • Hammer or framing nailer
  • Plumb bob
  • Drill
  • Masonry screws
Whether you are planning to add rooms to a basement or just to remodel, you will need to frame new walls for your basement drywall. You can do this project by yourself with the help of one other person. Follow these few helpful suggestions to complete framing of your wall in a few hours.
Step 1 – Measure and Mark Plate Lines
In your unfinished basement, mark on the ceiling joist at a place where the near end of your top wall plate will be attached. Make another mark where the far end will be attached. Snap a chalk line between the two marks. At one end of this line hold the end of a plumb bob string, then have your helper mark the place on the floor where the plumb bob touches. Do the same at the far end of the top plate, then snap a chalk line between these two points.
Step 2 – Mark Points for your Studs
Lay your bottom and top plates side by side on the floor, so the ends of both plates are even with each other. Use a pencil to mark both plates ¾-inch in from the end. This will be the center of your first wall stud. From the first stud mark, measure 16 inches and make another mark to be the center of your next stud. Continue this process until you've reached the end of your plates where you will place another mark on each plate.
Step 3 – Measure and Cut your Studs
Where your wall will be installed, measure the distance between the floor and the bottom surface of the ceiling joist, then subtract 3 inches to account for the thickness of each plate. For example if the distance between floor and ceiling joist is exactly 8 feet, then when you subtract 3 inches for the bottom and top stud, your stud should be cut exacly 7 ft. 9 inches.
Don't make the mistake of assuming the distance from floor to ceiling will be 8 feet for each stud. Typically, it will be, but not all construction is perfect, and their might be variations in your ceiling joists. Measure this distance at both ends of your bottom and top plates. Now, cut your studs the length you measured.
Step 4 – Attach your Top and Bottom Plates
Using a framing nailer, attach the top plate to the ceiling joist where you made the chalk line. Using a stud gun with concrete nails or a high speed drill with concrete screws, attach he bottom plate to the floor. Be sure you drive a nail or stud near the end of the two plates, but no closer to the end than 2 inches to avoid splitting the plates.
 forum activity
