How to Frame a Basic Mirror
what you'll need
- Mirror
- Aluminum or wood frame
- Foam-core backing
- Compression clips
- Hanging clips
- Hanging wire
- Eye screws
- Framing points
- Hammer
Framing a mirror is an easy way to add a personal aesthetic touch to any room. Custom frame shops can be pricey, and you can save a lot of money by doing the work yourself. Aluminum frame kits and pre-assembled wooden frames are great options for do-it-yourself framing. You'll be able to complete your framing projects with minimal expense and just a few household tools.
Aluminum Frames
Step 1 - Frame Types
Aluminum frames are inexpensive and flexible. Your local craft store will carry a variety of aluminum frame strips sold in pairs for easy assembly. Standard finishes include black, silver and gold. If your mirror is less than 2 feet long, an aluminum frame will be sturdy enough to offer secure hanging.
Step 2 - Preparation
Purchase 2 pairs of frame strips to accommodate the dimensions of your mirror and a sheet of 1/4 inch foam-core backing. Don’t forget to buy compression clips, hanging clips and hanging wire if they aren’t already included with the frame strips.
Step 3 - Assembly
- Trim the foam-core to size and assemble 3 sides of the frame face down on your worktable.
- Slide your mirror and foam-core into the frame and attach the third side.
- Before tightening the corner joints, flip over the frame and check that the corners are properly aligned.
- Turn the frame face down again and slide compression clips behind the foam-core; 1 clip every 6 inches should be sufficient to snugly hold the mirror in place.
Step 4 - Hanging
Secure hanging clips about 1/3 of the way down each side of the frame and string wire between them. Minimize slack in the wire; this will make it easier to locate hanging points. Knock some drywall hanging hardware into your wall, hang and level your mirror, and you’re done.
Wooden Frames
Pre-assembled wooden frames offer some advantages over aluminum frames. You’ll find a wider variety of designs to complement your room’s décor. Wooden frames will also offer secure support for larger mirrors. Unfortunately, if your mirror has non-standard dimensions, you may find it difficult to locate a suitable pre-assembled frame. In such a case, look for a slightly larger frame that includes a pre-cut mat board. The mat will conceal the edges of the mirror.
After choosing your wooden frame, purchase a pair of eye screws, a roll of hanging wire, and a box of framing points. If the frame doesn’t include a backing board, don’t forget to pick up a sheet of foam-core as well.
Step 3 - Assembly
- Cut the foam-core to fit the frame. If your mirror is smaller than the frame, you’ll need to attach it to the center of the foam-core backing board using spray adhesive.
- Lay the frame face down on your worktable and lay the mat, mirror and backing board in place.
- Secure them in place with framing points; about 1 every 3 inches should be sufficient.
- If you don’t have framing pliers, simply tap in the points using a wooden block held flush to the backing board.
- Insert eye screws approximately 1/3 of the way down each side of the frame and string hanging wire between them.
Now you’re ready to hang your framed mirror.
